Error Message |
Potential Cause |
Suggested Solution |
#100 Cannot establish communication |
No connection between the touchscreen and the motherboard |
- Restart the printer
- Remove the bottom plate of the printer and check if all touchscreen cables are properly connected to the motherboard, and if the touchscreen PCB (LCD transfer) is properly connected to the motherboard
- Contact your Reseller/Distributor
#101 Communication broken |
#102 Update error |
An error has occurred while installing the update |
#200 Small connector failure |
No connection / short circuit between the perforated plate and the heatbed |
- Check if the perforated plate is properly secured to the heatbed, and if the Pogo pins are not dirty or tarnished
- Check if the heatbed cable is properly connected to the heatbed
- Check if the heatbed cable is properly connected to the motherboard
- Heatbed cable replacement: M200 Plus / M300 Plus
- Heatbed cable adapter replacement
#201 Large connector failure |
No connection / short circuit between the heatbed and the motherboard |
- Check if the heated cable is properly connected to the motherboard
#202 Extruder cable failure |
No connection / short circuit between the extruder cable and the extruder |
#203 X/Y endstop failure |
No signal coming from the X/Y axis endstop when the extruder reaches the “home” position (front left corner of the housing) |
#204 Z endstop failure |
No signal coming from the Z-axis endstop when the platform is lowered to the very bottom |
- Ensure that nothing is blocking the platform while it is moving to the very bottom
- Check if the Z-axis endstop is properly connected
- Z-axis endstop replacement
#205 Processor’s power supply failure |
There is a problem with the main power supply |
- Check if the power supply is sufficient
- Replace the power cable
#206 Temperature error |
Too high extruder temperature or high extruder temperature changes |
- Check if the heater&thermocouple are properly installed and secured in the hotend
- Check if the extruder cable is properly connected
- Heater&thermocouple replacement
- Extruder cable replacement
- Extruder PCB replacement
#207 Hotend heating failure |
Too low extruder temperature |
