The waste container is the long, vertical box placed at the back of the workspace of the printer. It is equipped with two kinds of nozzle cleaning brushes: a PTFE brush and two silicone brushes. The brushes clean the nozzles and prevent waste material from accumulating on the surface of the print. Therefore, if you notice that the hotends and nozzles have become considerably dirty or if the two materials blend on the surface of the print and there is a lot of waste material on the tray around the print, replace the waste container brushes. This manual shows how to replace all waste container brushes.
Waste Container Removal
Remove the waste container by pressing on the handles on both sides and pulling it towards you.
Silicone Brushes Removal
Remove the silicone brushes.
Silicone Brushes Installation
Place the new brushes in their place.
Waste Container Installation
Set the waste container in its place and push it until it clicks.
