Z-PLA Pro is a natural material which has been developed using biodegradable PLA as one of the components. It allows you to print objects rich in details with high dimensional accuracy and surface quality that resembles the texture of gypsum casts. However, there are certain hardware requirements which have to be met in order to create the best printing environment for this particular material. Follow the steps from this manual to make printing with Z-PLA Pro easier and problem-free.
Hotend Requirements
Use a separate hotend that will be dedicated only for printing with Z-PLA Pro. The hotend should be new and not used with other materials during different projects.
Unload Z-PLA Pro from the hotend immediately after the printing process. Do not keep the overheated material loaded in the extruder so as to avoid material degradation in the nozzle.
Extruder Upper Fan Operation
Check if the extruder upper fan is operating properly. A faulty fan can cause Z-PLA Pro to overheat and, as a result, have a negative influence on the printing process.
Also, use compressed air to clean the extruder upper fan and its heat sink from dust.
Platform Calibration Requirements
You should calibrate the platform before loading Z-PLA Pro into the hotend – the extruder needs to be empty. The nozzle becomes very hot during the calibration and it could cause the material to overheat resulting in its poor performance.
Temperature Tips
Remove the side covers before using Z-PLA Pro. This material is sensitive to high temperatures so the recommended temperature in the print room is less than 25 °C.
