This manual shows how to remove the lid magnet as well as the lid sensor, and how to install new ones.
Opening the extruder chamber
Turn the printer off and unplug the power cable. Open the lid.
Detaching the lid magnet
Unscrew the two screws securing the magnet in the lid frame. Remove the magnet.
Moving the extruder
Move the extruder to the back of the housing in order to have easy access to the front right wiring cover in the extruder chamber.
Removing the inner steel plate
Unscrew the screws securing the inner steel plate and remove the plate.
Detaching the lid sensor
Unscrew the two screws securing the lid sensor in the housing. Remove the screws and detach the sensor.
Removing the motherboard cover
7
Unscrew the ten screws securing the outer steel plate on the right side of the printer. Next, unplug the fan cable from the motherboard. Remove the plate.
7
Disconnecting the lid sensor cable
Unplug the lid sensor cable from the motherboard.
8
Removing the lid sensor
Remove the lid sensor by pulling it out carefully.
9
Installing the new lid sensor
Insert the new lid sensor into its place. Guide the cable towards the motherboard.
10
Connecting the lid sensor cable
Plug the lid sensor cable into the motherboard.
11
Securing the lid sensor
Install the new lid sensor into its place and secure the sensor with the two screws.
12
Installing the motherboard cover
Plug the fan cable into the motherboard. Secure the outer steel plate on the right side of the printer with the ten screws.
13
Installing the inner steel plate
Attach the inner steel plate in its place and secure the plate with the screws.
14
Installing the new lid magnet
Secure the new magnet to the door frame with the two screws.
15
Closing the extruder chamber
Move the extruder to the center and close the lid.
