Before sending the Inventure to technical service, you have to pack the device in the original packaging. The whole process requires care and attention as the fragile elements of the printer may get damaged. The original shipping box has been designed to protect your equipment from risks connected to transport and storage. While preparing the package, carefully follow the steps from this manual.
Unloading the Model Material
From the menu choose Material, then Model, and Unload the model material. Follow the instructions provided on the display.
Open the left door by pressing the release buttons, turn the lock to OPEN, and remove the cartridge from the printer.
Unloading the Support Material
From the menu choose Material, then Support, and Unload the support material. Follow the instructions provided on the display.
Open the right door by pressing the release buttons, turn the lock to OPEN, and remove the cartridge from the printer.
Turn the printer off and unplug the power cable.
Securing the Extruder
Secure the extruder with the plastic foams.
Wrapping the Printer
Wrap the printer in security foil.
Putting the Printer in the Box
Place the cushioning at the bottom of the box. Use the handles to put the printer inside the box.
Placing the Top Cushioning
Place the top cushioning on the printer.
Packing the Printer
Pack the printer using the provided box.
Taping the Box
Tape the box.
