The Zortrax Inkspire is equipped with a carbon filter which absorbs unpleasant smells from the air that passes through the printing chamber. It is installed in the back right corner of the printer’s housing. In order to ensure proper filtration during the printing process, the filter should be replaced every 3-4 months, or once it becomes considerably dirty, e.g. with liquid resin. This manual shows how to properly replace the filter.
UV Cover Removal
Remove the UV cover.
Filter Removal
Remove the filter from the printer’s housing.
Filter Installation
Install the new filter in the printer’s housing.
UV Cover Installation
Install the UV cover on the printer.
