The Z-axis coupler is responsible for the platform’s movement along the Z axis. Therefore, if the platform does not move at all or it moves with difficulties and makes unusual noises, the Z-axis couple needs to be replaced. Before replacing the coupler, make sure that the screws on the coupler are properly tightened. More details can be found in the manual.
If the screws cannot be fully tightened, follow the steps from this manual to replace the Z-axis coupler.
| The following manual shows the M200 repair work. For the M300, these procedures are the same. |
Turn off the printer and unplug the power cable. Wait a few minutes for all the capacitors to discharge.
Grab the printer’s housing and change the printer’s position so that you can easily access the bottom plate.
Unscrewing the Bottom Plate, part 1
Unscrew the screws that secure the bottom plate on one side of the housing. Use a 2.5mm Allen key.
Turning the Printer
Turn the printer over.
Unscrewing the Bottom Plate, part 2
Unscrew the screws that secure the bottom plate on the other side of the housing. Use the same key.
Separating the Bottom Plate
Providing Better Access to the Z-Axis Coupler
Unfasten the two extruder cable straps and unplug the cable from the motherboard. Next, unfasten the third strap. Place the extruder cable between the power supply unit and the housing. Finally, grab the cables next to the motherboard and fasten the strap.
Unplugging the Z-Axis Motor Cable
Unplug the Z-Axis motor cable.
Loosening the Z-Axis Coupler Screws
Loosen the three Z-Axis coupler screws placed on the Z-Axis motor side.
Unscrewing the Z-Axis Motor
Unscrew the two screws that secure the Z-Axis motor. Remove the motor with its distance piece. Remove the two big screws from the housing.
Z-Axis Coupler Removal
Loosen the three Z-Axis coupler screws placed on the Z-Axis side. Remove the coupler.
Z-Axis Coupler Assembly
Install the Z-Axis coupler in its place and tighten the screws placed on the Z-Axis side.
Z-Axis Motor Assembly
Insert the two Z-Axis motor screws in the housing, hold them and put the motor with the distance piece on them. Next, tighten the screws.
Tightening the Z-Axis Coupler Screws
Tighten the three Z-Axis coupler screws placed on the Z-Axis motor side.
Plugging the Z-Axis Motor Cable
Plug the Z-Axis motor cable in.
Rearranging the Cables
Rearrange the cables to their original position: unfasten the strap next to the motherboard. Secure the extruder cable with the first strap and plug it in. Fasten the remaining straps.
Bottom Plate Installation
Securing the Bottom Plate, part 1
Secure the bottom plate on one side of the housing. Use a 2.5mm Allen key.
Turning the Printer
Securing the Bottom Plate, part 2
Secure the bottom plate on the other side of the housing. Use the same key.
Grab the printer’s housing and set the printer upright.
