The extruder printed cover is placed over the extruder in order to give protection to the extruder cable and all the cables plugged into the extruder PCB. The cover secures the extruder PCB on the extruder aluminum cover as well as functions as a distance piece between these two components. Therefore, if you notice visible signs of wear and tear on the extruder printed cover (cracks or breaks), replace the cover to avoid any kind of failures.
At first, print the cover and then replace it according to this manual. The model is available for download here.
The following manual shows the M200 repair work. For the M300, these procedures are the same. |
Unloading the Material
Extruder Upper Printed Cover Removal
Detach the extruder upper printed cover from the extruder.
Material Guide Removal
Detach the material guide from the extruder cover.
Unplugging the Extruder Cable
Unplug the extruder cable.
Unscrewing the Extruder PCB
Unscrew the two screws that secure the extruder PCB using a 2mm Allen key. Remove the PCB from the extruder.
Extruder Lower Printed Cover Removal
Remove the extruder lower printed cover.
Extruder Lower Printed Cover Assembly
Attach the new extruder lower printed cover to the extruder.
Extruder PCB Assembly
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, e.g. by wrapping against each other.
Plugging the Extruder Cable
Plug the extruder cable in.
Material Guide Assembly
Attach the material guide to the extruder cover. Next, secure the guide to the extruder cable with the material guide clamps.
Extruder Upper Printed Cover Assembly
Attach the extruder upper cover to the extruder lower cover.
