The following table summarizes all technical specifications and operational characteristics of the Zortrax M300 Plus.
| Device | |
| Build Volume | 300 x 300 x 300 mm [11.8 x 11.8 x 11.8 in] |
| Nozzle Diameter | 0.4 mm [0.016 in] – standard / 0.3 mm [0.012 in] / 0.6 mm [0.024 in] |
| Extruder | Single (compatible with demanding materials, e.g. TPU or nylon) |
| Extruder Cooling System | Radial fan cooling the extruder block; two fans cooling the print |
| Hotend | Single (v3) |
| Platform | Heated; perforated and glass plates are applicable |
| Material Endstop | Mechanical |
| Connectivity | Wi-Fi, Ethernet, USB |
| Operating System | Android |
| Processor | Quad Core |
| Touchscreen | 4″ IPS 800 x 480 |
| Camera | Yes |
| Printing | |
| Technology | LPD (Layer Plastic Deposition) – depositing melted material layer by layer onto the build platform |
| Layer resolution | 90 – 390 microns (for 0.4 mm / 0.016 in nozzle) |
| Minimal wall thickness | 450 microns (for 0.4 mm / 0.016 in nozzle) |
| Platform levelling | Automatic measurement of platform points’ height |
| Filaments | |
| Available Filaments | Full offer is available at: filaments |
| External filaments | Applicable |
| Support | Mechanically removed – printed with the same material as the model |
| Filament container | Spool |
| Filament diameter | 1.75 mm (0.069 in) |
| Temperature | |
| Maximum Printing Temperature (Extruder) | 290° C [554° F] |
| Maximum Platform Temperature | 105° C [221° F] |
| Ambient Operating Temperature | 20 – 30° C [68 – 86° F] |
| Storage Temperature | 0 – 35° C [32 – 95° F] |
| Electrical | |
| AC Input | 110 V ~ 5.9 A 50/60 Hz 240 V ~ 2.5 A 50/60 Hz |
| Maximum Power Consumption | 360 W |
| Software | |
| Software Bundle | Z-SUITE |
| Supported File Types | .stl, .obj, .dxf, .3mf, .ply |
| Supported Operating Systems | Mac OS Catalina and newer versions / Windows 10 and newer versions | Additional Information |
| Each delivered printer may have worked up to 90 hours during the quality control test prints | |
