| Error Number |
Potential Cause |
Suggested Solution |
| #2:1 |
Hotend: Critical temperature |
- Check if the heater&thermocouple are properly installed and secured in the hotend,
- Check if the extruder cable is properly connected,
- Heater&thermocouple replacement,
- Extruder cable replacement,
- Extruder PCB replacement
| #2:2 |
Hotend: Temperature drop |
| #2:3 |
Hotend: Sensor failure |
| #2:4 |
Hotend: Heater failure |
| #2:10 |
Hotend: Temperature fluctuation |
| #4:1 |
Platform Heating Plate: Critical temperature |
- Check if the heatbed cable is properly connected to the heatbed,
- Check if the heatbed cable is properly connected to the motherboard,
- Heatbed cable replacement,
- Heatbed cable adapter replacement
| #4:2 |
Platform Heating Plate: Temperature drop |
| #4:3 |
Platform Heating Plate: Sensor failure |
| #4:4 |
Platform Heating Plate: Heater failure |
| #4:10 |
Platform Heating Plate: Temperature fluctuation |
| #5:5 |
Endstop X: Homing failure |
- Check if the X-axis endstop is properly connected,
- Carry out X/Y axes maintenance,
- X-axis endstop replacement
| #6:5 |
Endstop Y: Homing failure |
- Check if the Y-axis endstop is properly connected,
- Y-axis endstop replacement
| #7:5 |
Bottom Endstop Z: Homing failure |
- Ensure that nothing is blocking the platform while it is moving to the very bottom,
- Check if the Z-axis endstop is properly connected,
- Check if the Z-axis motor is properly connected,
- Z-axis endstop replacement
| #8 |
Unable to communicate with the control board |
- Check the connection between the Android board and the motherboard,
- Contact your Reseller/Distributor
| #15 |
Cannot update the firmware |
- Android board cable replacement,
- Android board replacement,
| #17:16 |
Connection with GUI lost |
- Check if the Android PCB and LCD Display Through (adapter) are properly connected
- Android PCB/LCD Display Through (adapter) replacement
| #19 |
GUI doesn’t receive packages |
- Restart the device,
| #20:17 |
Platform Small Connector: Not detected |
- The small connector might be unplugged or damaged
| #22 |
Unable to determine bootloader version |
| #23 |
Cannot start communication with motherboard |
| In the case of other error messages, contact Zortrax Customer Support through the Support Form and provide details and pictures. |
