The extruder cable is the ribbon cable that supplies the extruder with power and allows the motherboard to regulate the printing process. If you experience problems with extruder heating, and your models have incomplete layers or irregular walls, or there are material deficiencies in their structure, the extruder cable needs to be replaced. Follow the steps from this manual see how to properly replace the cable.
