The endstop sleeve is responsible for pressing the lever of the endstop once the extruder reaches the end of the axis. This action immediately informs the printer that the extruder should stop moving and not crash into the housing. Therefore, if the extruder keeps hitting a corner of the housing, and an error message appears on the display (Endstops error #034), check if the endstop sleeves are installed on each axis block. The sleeves should be attached to the inner side of the axis block. This manual gives instructions on the endstop sleeve installation. There is an endstop sleeve model available for download at the Zortrax Library.
| The following manual shows the M200 repair work. For the M300, M200 Plus and M300 Plus, these procedures are the same. |
Unplugging the Extruder Cable
Unplug the extruder cable.
Loosening the Screws on the Axis Block
Move the extruder toward the axis block on which you will install the endstop sleeve. Loosen the two screws placed at the bottom of the opposite axis block using a 1.5mm Allen key.
Unscrewing the Axis Block Cover
Move the extruder toward the opposite axis block. Unscrew the two front screws on the axis block on which you will install the endstop sleeve. Use a 2mm Allen key. Slightly move the axis block cover away from the block to gain easier access to the place where the endstop sleeve should be screwed in.
Endstop Sleeve Installation
Turn the axis block and screw in the endstop sleeve using a 2mm Allen key. Turn the axis block to its previous position.
Securing the Axis Block Cover
Push the axis block cover closer to the block and secure it with the two screws.
Tightening the Screws on the Axis Block
Move the extruder toward the opposite axis block. Tighten the two screws placed at the bottom of the axis block using a 1.5mm Allen key.
Plugging the Extruder Cable
Plug the extruder cable in.
