The following table summarizes all technical specifications and operational characteristics of the Zortrax M200 Plus.
Weight and Physical Dimensions
Without a Spool 350 x 360 x 505 mm [13.8 x 14.2 x 19.9 in]
With a Spool 350 x 430 x 505 mm [13.8 x 16.9 x 19.9 in]
Shipping Box 470 x 480 x 570 mm [18.5 x 18.9 x 22.4 in]
Shipping Weight 26 kg [57.3 lb]
Printer Weight* 16 kg [32 lb]
Printing
Technology LPD (Layer Plastic Deposition) – depositing melted material layer by layer onto the build platform
Layer Resolution 90 – 390 microns
Minimal Wall Thickness 400 microns
Dimensional Accuracy +/- 0.2%*
Angle Accuracy +/- 0.2%**
Platform Levelling Automatic measurement of platform points’ height
3D Printer
Build Volume 200 x 200 x 180 mm [7.9 x 7.9 x 7.1 in]
Material Container Spool
Material Diameter 1.75 mm [0.069 in]
Nozzle Diameter 0.4 mm [0.016 in]
Support Mechanically removed – printed with the same material as the model
Extruder Single (upgraded for more demanding materials)
Extruder Cooling System Radial fan cooling the extruder block; two fans cooling the print
Hotend Redesigned (v3), new geometry of the nozzle
Material Endstop Mechanical
Platform Perforated, equipped with Pogo pins
Connectivity USB, Ethernet, WIFI
Operating System Android
Processor Quad Core
Touchscreen 4″ IPS 800 x 480
Camera Yes
Available Materials Full offer is available at: zortrax.com/materials/zortrax-m-series/
External Materials Applicable
Temperature
Maximum Printing Temperature 290˚ C [554˚ F]
Platform Heated
Maximum Platform Temperature 105˚ C [221˚ F]
Ambient Operating Temperature 20 – 30˚ C [68 – 86° F]
Storage Temperature 0 – 35˚ C [32 – 95° F]
Electrical
AC Input 110V ~ 5.9A 50/60Hz
240V ~ 2.5A 50/60Hz
Maximum Power Consumption 320 W
Software
Software Bundle Z-SUITE 2®
Supported File Types .stl, .obj, .dxf, .3mf
Output file types .zcodex
Supported Operating Systems Mac OS X / Windows 7 and newer versions
Additional Information
Each delivered printer may have worked up to 50 hours during the quality control test prints
* The weight of material spool is not included.
**It should be noted that the model’s dimensions strongly depend on the technical condition of the printer as well as the shape, form and size of a print, the material used and the printing process conditions. The Z-axis accuracy does not include a tolerance of +/- one layer. Bear in mind errors of measurement and measuring equipment.
***Measurements were taken with an angle of 90˚.
