The bottom fan maintains the proper temperature around the motherboard and protects it from overheating. If you can hear a strange sound coming from the bottom of the machine, at first you should check if something is not obstructing the fan’s blades from moving. If the blades do not rotate at all even though the printer is on, the fan is probably faulty and needs to be replaced. Follow the instructions from this manual to avoid motherboard failure in your printer.
The following manual shows the M200 repair work. For the M300, these procedures are the same.
Turn off the machine and unplug the power cable. Wait a few minutes for all the capacitors to discharge.
Grab the printer’s housing and change the printer’s position so that you can easily access the bottom plate.
Unscrewing the Bottom Plate, part 1
Unscrew the screws that secure the bottom plate on one side of the housing. Use a 2.5mm Allen key.
Turning the Printer
Turn the printer over.
Unscrewing the Bottom Plate, part 2
Unscrew the screws that secure the bottom plate on the other side of the housing. Use the same key.
Separating the Bottom Plate
7
Unscrewing the Bottom Fan
Unscrew the bottom fan from the plate using a 2.5 mm Allen key. Remove the bottom fan cable from the clamp and separate the fan from the bottom plate.
8
Bottom Fan Installation
Bend the bottom fan cable and pass it through the clamp. Install the bottom fan in its place and secure it with the screws.
9
Bottom Plate Installation
10
Securing the Bottom Plate, part 1
Secure the bottom plate with the screws on one side of the housing. Use a 2.5mm Allen key.
11
Turning the Printer
12
Securing the Bottom Plate, part 2
Secure the bottom plate with the screws on the other side of the housing. Use the same key.
13
Grab the printer’s housing and set the printer upright.
14
