The extruder lower fan is an essential part of the extruder which has a direct influence on the quality of the printed objects. It ensures that each layer of the material is cooled down so that the next one can be applied onto it without causing them to split apart. Therefore, if you notice imperfections on the surface of the model, for example, the model melts, and you can warping or burn marks, it may indicate the extruder lower fan failure. Also, if the fan generates unusual noises, or its blades don’t spin, replace the fan to avoid having a failed print. The following manual shows how to replace the extruder lower fan.
Opening the Top Door
Open the top door.
Unplugging the Extruder Cable
Unplug the extruder cable.
Unplugging the Extruder Lower Fan Cable
Unplug the extruder lower fan cable.
Unlocking the Material Guides
Unlock the material guide tube switches on both sides of the extruder using a flathead screwdriver.
Detaching the Material Guides
Bend the outer material guide gently and move it up and down until you detach it. Repeat this step with the other material guide. Detach both material guide tubes from the extruder.
7
Unscrewing the Extruder
Unscrew the two screws securing the extruder.
8
Extruder Removal
Remove the extruder from the printer.
9
Unscrewing the Extruder Lower Fan
Unscrew the extruder lower fan and remove the fan shroud.
10
Extruder Lower Fan Removal
Pass the extruder lower fan cable through the hole and remove the fan from the printer.
11
Extruder Lower Fan Installation
Put the fan shroud together with the new extruder lower fan. Pass the extruder lower fan cable through the hole and place the fan in its place.
12
Securing the Extruder Lower Fan
Secure the extruder lower fan with the screw.
13
Extruder Assembly
Place the extruder back in the printer.
14
Secure the extruder with the two screws.
15
Attaching the Material Guides
Attach the material guide tube to the extruder. Next, install the outer material guide gently in its place. Repeat this step with the other material guide.
16
Locking the Material Guides
Lock the material guide tube switches on both sides of the extruder using a flathead screwdriver.
17
Plugging the Extruder Lower Fan Cable
Plug the extruder lower fan cable in.
18
Plugging the Extruder Cable
Plug the extruder cable in.
19
Closing the Top Door
Close the top door.
