The extruder aluminum block is one of the main parts of the extruder. It holds most of the components which are necessary for the printing process, including the hotend, extruder motor, or fans. It is sometimes possible that the material gets blocked within the material duct inside the extruder aluminum block. If you encounter problems during material loading or extrusion, at first you should check whether the hotend or nozzle are not clogged. If problems still exist, inspect the extruder block. Remove material residues that have accumulated in the duct with a needle or an Allen key. If the duct cannot be unblocked mechanically, replace the extruder aluminum block. This manual shows the correct replacement procedure.
The following manual shows the M200 repair work. For the M300, these procedures are the same. |
Unloading the Material
Material Guide Removal
Detach the material guide from the extruder cover. Next, separate the guide from the extruder cable.
Unplugging the Extruder Cable
Detach the extruder upper printed cover and unplug the extruder cable.
Unscrewing the Extruder PCB
Unscrew the two screws that secure the extruder PCB using a 2mm Allen key. Remove the PCB from the extruder.
Extruder Lower Printed Cover Removal
Remove the extruder lower printed cover.
Extruder Aluminum Cover Removal
Unscrew the screws that secure the extruder aluminum cover on both sides of the extruder. Separate the cover from the extruder motor.
Extruder Motor Removal
Unscrew the four screws that secure the extruder motor. Separate the motor from the extruder block.
Unscrewing the Axis Block Covers, part 1
Unscrew one of the screws that secures the axis block cover on each block.
Unscrewing the Axis Block Covers, part 2
Unscrew the other screw that secures the axis block cover on each block.
Extruder Removal
Remove the extruder along with its guide rails.
Extruder Guide Rails Removal
Loosen the two screws on the axis block cover and separate the cover from the extruder guide rail. Next, remove the rail from the extruder.
Loosen the two screws placed under the other axis block cover and separate the cover from the extruder guide rail. Remove the rail from the extruder.
Hotend Removal
Unscrew the two screws that secure the hotend in the extruder. Remove the hotend from the extruder and remove the heater, thermocouple and fans cables from the extruder block.
Extruder Lower Fan Removal
Unscrew the three screws that secure the extruder lower fan, separate the fan from the heat sink and remove the distance piece.
Extruder Upper Fan Removal
Unscrew the four screws that secure the heat sink with the extruder upper fan. Separate the heat sink from the extruder block.
Extruder Bearing Removal
Unscrew one screw that secures the extruder bearing. Remove the bearing using tweezers.
Extruder Linear Bearings Removal
Loosen the two screws that secure the extruder linear bearing and remove the bearing from the extruder aluminum block.
Remove the remaining bearings likewise. There are four linear bearings altogether.
Extruder Bearing Assembly
Insert the extruder bearing into the new extruder aluminum block and secure it with the screw.
Extruder Upper Fan Assembly
Join the extruder aluminum block with the extruder upper fan heat sink and tighten the four screws.
Extruder Lower Fan Assembly
Place the extruder lower fan in its place and tighten the three screws. Remember to place the distance piece.
Hotend Assembly
Insert the hotend into the extruder and tighten the two screws.
Extruder Linear Bearings Assembly
Insert the extruder linear bearing into the extruder and secure it with the two screws.
Install the remaining bearings likewise. There are four linear bearings altogether.
Extruder Guide Rails Assembly
Insert the extruder guide rails into the extruder and place the axis block covers on both rails. Be careful not to damage the linear bearings – insert the guide rails at a straight angle.
Extruder Installation
Install the extruder with its guide rails in the printer.
Securing the Axis Block Covers, part 1
Tighten the screws that secure the axis block cover on each block.
Securing the Axis Block Covers, part 2
Tighten the other screws on each axis block.
Tightening the Screws on the Axis Block Covers, part 1
Finish tightening the screws on the axis block covers.
Tightening the Screws on the Axis Block Cover, part 2
Secure the axis block covers to the extruder guide rails by tightening the screws shown in the video.
Extruder Motor Assembly
Reattach the extruder motor to the extruder block and secure the motor with the screws. Press the motor to the right side so that the bearing rack is as close as possible to the bearing. Tighten the screws crosswise in the following order: 1-4, 2-3.
Extruder Aluminum Cover Assembly
Reattach the extruder aluminum cover to the extruder and secure it with the screws.
Extruder Lower Printed Cover Assembly
Attach the extruder lower printed cover to the extruder.
Extruder PCB Assembly
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, e.g. by wrapping against each other.
Plugging the Extruder Cable
Plug the extruder cable in, and then attach the extruder upper cover to the lower cover.
Material Guide Installation
Attach the material guide to the extruder cover. Next, secure the guide to the extruder cable with the material guide clamps.
