Platform maintenance is necessary to keep the platform clean and in good condition. The maintenance procedures improve the printing process and make it more trouble-free. Also, platform maintenance can help you resolve problems with platform calibration, especially its center point. Once you carry out the maintenance work, your model will properly adhere to the platform and, at the same time, it will be easier for you to remove it once the printing process is finished. This manual provides the correct maintenance procedure.
Remember to calibrate the platform after completing platform maintenance. |
Unplugging the Heatbed Cable
Unplug the big connector of the heatbed cable from the platform.
Platform Removal
Unplugging the Perforated Plate Cable
Unplug the two small connectors on both sides of the platform and remove the perforated plate cable.
Cleaning the Platform
Clean the platform from the material residues using a spatula.
Unscrew the screws that secure the perforated plate to the heatbed. Remove the perforated plate.
Cleaning the Heatbed
Remove the material residues from the heatbed using a piece of cloth and, if it is necessary, use a spatula.
Cleaning the Perforated Plate with a Spatula
Turn the perforated plate over and clean it from the material remains using a spatula.
Securing the Perforated Plate
Secure the perforated plate to the heatbed with the screws. At the end loosen the two screws that secure the platform in the centre position by 30-45 degrees.
Plugging the Perforated Plate Cable
Plug in the perforated plate cable on both sides of the platform.
Platform Installation
Put the platform back in the printer.
Plugging the the Heatbed Cable
Plug the big connector of the heatbed cable in.
Platform Calibration
Once the maintenance work is done, the platform needs calibration.
