The following table summarizes technical specification and operational characteristics of the Zortrax M300 Dual.
Device
Build Volume 265 x 265 x 300 mm [10.4 x 10.4 x 11.8 in]
Nozzle Diameter 0.4 mm [0.016 in] – standard, 0.6 mm [0.024 in]
Extruder Dual, printing with model and support material
Extruder Cooling System Two fans cooling the extruder; radial fan cooling the print
Hotend Dual
Platform Heated; perforated and glass plates are applicable
Material Endstop 2 x mechanical
Connectivity Wi-Fi, Ethernet, USB
Operating System Android
Processor Quad Core
Touchscreen 4″ IPS 800 x 480
Camera Yes
Printing
Technology LPD Plus (Layer Plastic Deposition Plus) – advanced technology depositing melted thermoplastics with dissolvable support structures
Layer Resolution 150 – 300 microns (for 0.4 mm / 0.016 in nozzle)
Minimal Wall Thickness 450 microns (for 0.4 mm/0.016 in nozzle)
Platform Levelling Automatic measurement of platform points’ height / manual measurement of platform points’ height
Filaments
Available Filaments Full offer is available at: filaments
External filaments Applicable
Support Mechanically removed – printed with the same material as the model
Water-soluble – printed with a different material than the model
Filament container Spool
Filament diameter 1.75 mm (0.069 in)
Temperature
Maximum printing temperature (extruder) 310° C [590° F]
Maximum Platform Temperature 105° C [221° F]
Ambient Operating Temperature 20 – 30° C [68 – 86° F]
Storage Temperature 0 – 35° C [32 – 95° F]
Electrical
AC Input 110 V ~ 5.9 A 50/60 Hz
240 V ~ 2.5 A 50/60 Hz
Maximum Power Consumption 400 W
Software
Software Bundle Z-SUITE
Supported File Types .stl, .obj, .dxf, .3mf, .ply
Supported Operating Systems Mac OS Catalina and newer versions / Windows 10 and newer versions
Additional Information
Each delivered printer may have worked up to 90 hours during the quality control test prints
