| Error Number |
Potential Cause |
Suggested Solution |
| #1 |
Upper fan: not working |
- Select the Run upper fan option from the menu and check if the fan is working
- If the fan is not working:
1)ensure that the fan’s blades are not mechanically blocked,
2)check if the fan is properly connected to the extruder PCB,
3)upper fan replacement
| #2 |
Bottom fan: not working |
- Select the Run bottom fan option from the menu and check if the fan is working
3)bottom fan replacement
| #2:1 |
Left Hotend: Critical temperature |
- Check if the heater&thermocouple are properly installed and secured in the hotend,
- Check if the extruder cable is properly connected,
- Heater&thermocouple replacement,
- Extruder cable replacement,
- Extruder PCB replacement
| #2:2 |
Left Hotend: Temperature drop |
| #2:3 |
Left Hotend: Sensor Failure |
| #2:4 |
Left Hotend: Heater failure |
| #2:10 |
Left Hotend: Temperature fluctuation |
| #3:1 |
Right Hotend: Critical temperature |
| #3:2 |
Right Hotend: Temperature drop |
| #3:3 |
Right Hotend: Sensor Failure |
| #3:4 |
Right Hotend: Heater failure |
| #3:10 |
Right Hotend: Temperature fluctuation |
| #4:1 |
Platform Heating Plate: Critical temperature |
- Check if the heatbed cable is properly connected to the heatbed,
- Check if the heatbed cable is properly connected to the motherboard,
- Heatbed cable replacement,
- Heatbed cable adapter replacement
| #4:2 |
Platform Heating Plate: Temperature drop |
| #4:4 |
Platform Heating Plate: Heater failure |
| #4:10 |
Platform Heating Plate: Temperature fluctuation |
| #5:5 |
Endstop X: Homing failure |
- Check if the X-axis endstop is properly connected,
- Make sure that the metal strip installed on the axis block enters the endstop,
- Carry out X/Y axes maintenance,
- X-axis endstop replacement
| #6:5 |
Endstop Y: Homing failure |
- Check if the Y-axis endstop is properly connected,
- Y-axis endstop replacement
| #7:5 |
Bottom Endstop Z: Homing failure |
- Ensure that nothing is blocking the platform while it is moving to the very bottom,
- Check if the Z-axis endstop is properly connected,
- Z-axis endstop replacement
| #8 |
Unable to communicate with the control board |
- Check the connection between the Android board and the motherboard,
- Contact your Reseller/Distributor
| #11:3 |
Cap Sensor: Sensor failure |
- Check if the capacitive sensor is properly connected to the extruder PCB and installed in the fan shroud
| #15 |
Cannot update the firmware |
- Android board cable replacement,
- Android board replacement,
| #15:8 |
Extruder PCB: No connection |
| #15:11 |
Extruder PCB: Overheating |
- Check if the ambient temperature does not exceed 30° C [86° F],
- If the ambient temperature is higher than 30° C [86° F], turn the printer off and unplug the power cable. Wait until the temperature falls below the recommended value,
- Extruder PCB replacement,
| #16:12 |
Power Supply: Overheating |
- Turn the printer off and unplug the power cable,
| #17:13 |
Motherboard: Overheating |
| #19 |
GUI doesn’t receive packages |
- Restart the device,
| #22 |
Unable to determine bootloader version |
| #23 |
Cannot start communication with motherboard |
| In the case of other error messages, contact Zortrax Customer Support through the Support Form and provide details and pictures. |
