The following table summarizes all technical specifications and operational characteristics of the Zortrax M200 Plus.
Device | |
Build Volume | 200 x 200 x 180 mm [7.9 x 7.9 x 7.1 in] |
Nozzle Diameter | 0.4 mm [0.016 in] – standard / 0.3 mm [0.012 in] / 0.6 mm [0.024 in] |
Extruder | Single (compatible with demanding materials, e.g. TPU or nylon) |
Extruder Cooling System | Radial fan cooling the extruder block; two fans cooling the print |
Hotend | Single (v3) |
Platform | Heated; perforated and glass plates are applicable |
Material Endstop | Mechanical |
Connectivity | Wi-Fi, Ethernet, USB |
Operating System | Android |
Processor | Quad Core |
Touchscreen | 4″ IPS 800 x 480 |
Camera | Yes |
Printing | |
Technology | LPD (Layer Plastic Deposition) – depositing melted material layer by layer onto the build platform |
Layer Resolution | 90 – 390 microns |
Minimal Wall Thickness | 450 microns – for 0.4 mm nozzle |
Platform Levelling | Automatic measurement of platform points’ height |
Filaments | |
Available Filaments | Full offer is available at: filaments |
External materials | Applicable |
Support | Mechanically removed – printed with the same material as the model |
Filament container | Spool |
Filament diameter | 1.75 mm (0.069 in) |
Temperature | |
Maximum Printing Temperature (Extruder) | 290˚ C [554˚ F] |
Maximum Platform Temperature | 105˚ C [221˚ F] |
Ambient Operating Temperature | 20 – 30˚ C [68 – 86° F] |
Storage Temperature | 0 – 35˚ C [32 – 95° F] |
Electrical | |
AC Input | 110 V ~ 5.9 A 50/60 Hz 240 V ~ 2.5 A 50/60 Hz |
Maximum Power Consumption | 320 W |
Software | |
Software Bundle | Z-SUITE |
Supported File Types | .stl, .obj, .dxf, .3mf, .ply |
Supported Operating Systems | Mac OS Catalina and newer versions / Windows 10 and newer versions |
Additional Information | |
Each delivered printer may have worked up to 50 hours during the quality control test prints |
