The following table summarizes all technical specifications and operational characteristics of Zortrax Inventure 3D printer.
| Device | |
| Build Volume | 135 x 135 x 130 mm [5.3 x 5.3 x 5.1 in] |
| Nozzle Diameter | 0.4 mm [0.015 in] |
| HEPA Filter | Yes |
| Material Detection Sensor | Yes (for filaments in cartridge only) |
| Chip with information about material (type, color, consumption) | Yes (for filaments in cartridge only) |
| Extruder | Dual, printing with model and support material |
| Hotend | Dual |
| Connectivity | SD card (included) |
| Printing | |
| Technology | LPD Plus (Layer Plastic Deposition Plus) – advanced technology with the system of Dissolvable Support Structures |
| Layer Resolution | 150 – 300 microns |
| Minimal Wall Thickness | 450 microns |
| Platform Levelling | Automatic measurement of platform points’ height |
| Filaments | |
| Available Filaments | Full offer is available at: filaments |
| External filaments | Applicable |
| Support | Water-soluble – printed with a different material than the model Mechanically removed – printed with the same material as the model |
| Material container | Cartridge or spool |
| Material diameter | 1.75 mm (0.069 in) |
| Temperature | |
| Heated Chamber | Yes |
| Ambient Operating Temperature | 15 – 30˚ C [59 – 86° F] |
| Storage Temperature | 0 – 35˚ C [32 – 95° F] |
| Electrical | |
| AC Input | 110V ~ 4A 50/60Hz 240V ~ 1.7A 50/60Hz |
| Maximum Power Consumption | 300 W |
| Software | |
| Software Bundle | Z-SUITE |
| Supported File Types | .stl, .obj, .dxf, .3mf |
| Supported Operating Systems | Mac OS up to Catalina version / Windows 10 and newer versions | Additional Information |
| Each delivered printer may have worked up to 50 hours during the quality control test prints | |
