The following table summarizes all technical specifications and operational characteristics of the Zortrax Inkspire.
| Printing | |
| Technology | UV LCD* – projecting a shape of a layer on the underside of the tank with liquid resin and curing the layer with a UV lamp |
| Layer Thickness | 25, 50, 100 microns |
| Pixel size | 50 microns (0.05 mm) |
| Device | |
| Build Volume | 132 x 74 x 175 mm [2.9 x 5.2 x 6.9 in] |
| Platform Calibration | Semi-automatic |
| Support | Mechanically removed – printed with the same material as the model |
| Light Source | Integrated UV lamp (wavelength 405 nm) |
| Connectivity | Wi-Fi, Ethernet, USB |
| Operating System | Android |
| Processor | Quad Core |
| Touchscreen | 4″ IPS 800 x 480 |
| Available Materials | Full offer is available at: zortrax.com/resins. |
| External Materials** | Applicable |
| Supported Formats | .cws, .zcodex, .sl1, .zip |
| Temperature | |
| Ambient Operating Temperature | 20 – 30˚ C [68 – 86° F] |
| Storage Temperature | 0 – 35˚ C [32 – 95° F] |
| Electrical | |
| AC Input | 110V ~ 1.4 A 50/60Hz 240V ~ 0.85 A 50/60Hz |
| Maximum Power Consumption | 75 W |
| Software | |
| Software Bundle | Z-SUITE 2® |
| Supported File Types | .stl, .obj, .dxf, .3mf, .ply |
| Supported Operating Systems | Mac OS Catalina and newer versions / Windows 10 and newer versions | Additional Information |
| All information contained in this specification is subject to change without notice | |
*The LCD screen has suggested replacement time of about 200 working hours. This period highly depends on the type of resin you use most often.
**Predefined printing profiles for third-party resins are periodically added to Z-SUITE in cooperation with industry-leading resin manufacturers.
