The following table summarizes all technical specifications and operational characteristics of the Zortrax Apoller.
Every unit requires an annual inspection conducted by the Zortrax Authorized Service to keep the ATEX certification valid and ensure safe operation of the device.
Device
Build Volume 300 x 250 x 250 mm [11.8 x 9.8 x 9.8 in]
Connectivity Wi-Fi, Ethernet, USB
Operating System Android
Processor Quad Core
Touchscreen 4″ IPS 800 x 480
Solvent Compatibility Pure acetone or pure butanone (MEK)*
Zortrax Compatible Materials Z-ABS, Z-ULTRAT, Z-ULTRAT Plus, Z-ASA Pro, Z-HIPS
External Compatible Materials ABS, ASA, HIPS
Process
Maximum Working Temperature 90° C [194° F]
Minimum Working Temperature -20° C [-4° F]
Minimum Gauge Working Pressure -0.6 bar
Ambient Operating Temperature 15-30° C [59-86° F]
Storage Temperature 0-35° C [32-95° F]
Electrical
AC Input 110 V ~ 13.6 A 50/60 Hz
240 V ~ 6.3 A 50/60 Hz
Power Supply Parameters 24 V DC @ 21 A, 500 W
Maximum Power Consumption 1500 W
*Only pure acetone or MEK are supported and safe to use. Using other solvents may be dangerous and should not be attempted.
