Zortrax Resin PRO requires special preparation before the printing process as it is prone to segmentation which can influence the printing quality. Every time you use this type of resin, you have to mix the liquid in the bottle and make sure that there are no air bubbles in the resin once you fill the tank. Bubbles in liquid resin can make it impossible for the device to print a full raft and, as a result, significantly lower the model’s adhesion to the platform. Follow the instructions from this manual to avoid printing problems with Resin PRO.
Mixing the Resin
Mix the resin well by shaking the bottle for 3-5 minutes.
Filling the Tank
Once you fill the tank with Resin PRO, wait 5+ minutes before starting the printing process. Make sure that no air bubbles remain in the resin.
Prints made with Resin PRO do not require additional curing after the printing process.
Emptying the Tank
If you don’t plan to restart the printing process, empty the tank right after the print is complete.
