The following table summarizes all technical specifications and operational characteristics of the Zortrax HEPA Cover.
Weight and Physical Dimensions
HEPA Cover 200 HEPA Cover 300
Without filtering module 368 x 357 x 230 mm [14.5 x 14.1 x 9.1 in] 496 x 483 x 280 mm [19.5 x 19.1 x 11 in]
With filtering module 426 x 357 x 230 mm [16.8 x 14.1 x 9.1 in] 545 x 483 x 280 mm [21.5 x 19.1 x 11 in]
Device weight 1.95 kg [4.3 lb] 2.55 kg [5.6. lb]
Filtration
Odor Reduction Filter Carbon
Particle Reduction Filter HEPA
Filtration Efficiency 99.5%
Electrical
AC Input 110 – 240 V ~ 0.7 A 50/60 Hz
Power Supply Parameters 12 V DC, 0.5 A (min)
Maximum Power Consumption 6 W
Compatible Products
3D Printers M200 / M200 Plus M300 / M300 Plus
