Error Number |
Potential Cause |
Suggested Solution |
#1 |
Upper fan: not working |
- Select the Run upper fan option from the menu and check if the fan is working
- If the fan is not working:
1)ensure that the fan’s blades are not mechanically blocked,
2)check if the fan is properly connected to the extruder PCB,
3)upper fan replacement
#2 |
Bottom fan: not working |
- Select the Run bottom fan option from the menu and check if the fan is working
3)bottom fan replacement
#2:1 |
Left Hotend: Critical temperature |
- Check if the heater&thermocouple are properly installed and secured in the hotend,
- Check if the extruder cable is properly connected,
- Heater&thermocouple replacement,
- Extruder cable replacement,
- Extruder PCB replacement
#2:2 |
Left Hotend: Temperature drop |
#2:3 |
Left Hotend: Sensor Failure |
#2:4 |
Left Hotend: Heater failure |
#2:10 |
Left Hotend: Temperature fluctuation |
#3:1 |
Right Hotend: Critical temperature |
#3:2 |
Right Hotend: Temperature drop |
#3:3 |
Right Hotend: Sensor Failure |
#3:4 |
Right Hotend: Heater failure |
#3:10 |
Right Hotend: Temperature fluctuation |
#4:1 |
Platform Heating Plate: Critical temperature |
- Check if the heatbed cable is properly connected to the heatbed,
- Check if the heatbed cable is properly connected to the motherboard,
- Heatbed cable replacement,
- Heatbed cable adapter replacement
#4:2 |
Platform Heating Plate: Temperature drop |
#4:4 |
Platform Heating Plate: Heater failure |
#4:10 |
Platform Heating Plate: Temperature fluctuation |
#5:5 |
Endstop X: Homing failure |
- Check if the X-axis endstop is properly connected,
- Make sure that the metal strip installed on the axis block enters the endstop,
- Carry out X/Y axes maintenance,
- X-axis endstop replacement
#6:5 |
Endstop Y: Homing failure |
- Check if the Y-axis endstop is properly connected,
- Y-axis endstop replacement
#7:5 |
Bottom Endstop Z: Homing failure |
- Ensure that nothing is blocking the platform while it is moving to the very bottom,
- Check if the Z-axis endstop is properly connected,
- Z-axis endstop replacement
#8 |
Unable to communicate with the control board |
- Check the connection between the Android board and the motherboard,
- Contact your Reseller/Distributor
#11:3 |
Cap Sensor: Sensor failure |
- Check if the capacitive sensor is properly connected to the extruder PCB and installed in the fan shroud
#15 |
Cannot update the firmware |
- Android board cable replacement,
- Android board replacement,
#15:8 |
Extruder PCB: No connection |
#15:11 |
Extruder PCB: Overheating |
- Check if the ambient temperature does not exceed 30° C [86° F],
- If the ambient temperature is higher than 30° C [86° F], turn the printer off and unplug the power cable. Wait until the temperature falls below the recommended value,
- Extruder PCB replacement,
#16:12 |
Power Supply: Overheating |
- Turn the printer off and unplug the power cable,
#17:13 |
Motherboard: Overheating |
#19 |
GUI doesn’t receive packages |
- Restart the device,
#22 |
Unable to determine bootloader version |
#23 |
Cannot start communication with motherboard |
In the case of other error messages, contact Zortrax Customer Support through the Support Form and provide details and pictures. |
