The extruder top cover V2 features enhanced functionalities of the extruder cover V1. The modernized version of the cover provides even more effective protection to the extruder cable. Thanks to the fastener included in the upper part of the cover, the extruder cable is tightly secured right next to its connector where severe deformation can occur during the printing process. The extruder top cover V2 makes material feeding easier through a redesigned hole for the material guide.
We highly recommend replacing the cover V1 with the cover V2. First, you need to 3D print the model available: here and follow these steps to upgrade the extruder top cover from V1 to V2.
M Series Printers Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Unloading the Material
Unplugging the Extruder Cable
Unplug the extruder cable.
Upper Printed Extruder Cover V1 Removal
Detach the upper printed extruder cover V1 from the extruder.
Unplug all the cables from the extruder PCB: the fans cable, the heater & thermocoupler cable and the extruder motor cable.
Unscrewing the Extruder PCB
Unscrew the two screws securing the extruder PCB using a 2mm Allen key. Remove the PCB from the extruder.
Lower Printed Extruder Cover V1 Removal
Remove the lower printed extruder cover V1.
Lower Printed Extruder Cover V2 Assembly
Attach the lower printed extruder cover V2 to the extruder.
Extruder PCB Assembly
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, e.g. by wrapping against each other.
Plugging the Extruder Cable
Plug the extruder cable in.
Material Guide Assembly
Attach the material guide to the extruder cover V2.
Upper Printed Extruder Cover V2 Assembly
Attach the upper extruder cover V2 to the lower cover.
