In order to avoid damages during shipment, the M200 is packaged in foil, foams and other protective materials. Unpacking of the M200 needs to be dealt with carefully as the fragile elements of the printer may be damaged during the process. Once you receive the box with the printer, carefully follow the steps provided in this manual to properly unpack your M200.
Opening the Box
Opening the Box
Open the box and remove the upper cushioning.
Taking the Printer out of the Box
Take the 3D printer out of the box.
When lifting or moving the printer, do not grab:
  • belts
  • shipping clips
  • extruder
Removing the Foil
Removing the Foil
Remove the foil.
Removing the Fillers
Remove the fillers.
Removing the Shipping Clips
Remove the shipping clips.
Removing the Foam and the Starter Kit
Remove the foam with accessories and the Starter Kit box.
In the Box
In the Box
The graphic shows the whole box content.
