Removing the print needs to be dealt with very carefully because there are some elements of the printer that can get damaged in the process, for example the small connector placed at the edge of the platform. This manual shows the correct procedure connected to removing the print from the platform.
Wait 30-50 minutes until the platform and the print cool down.
Unplugging the Heatbed Cable
Unplug the heatbed cable from the platform. Both the big and small connectors need to be unplugged.
Platform Removal
Removing the Print
Use the spatula to remove the print.
Remove the print very carefully. Do not point the blade of the spatula towards the platform connectors.
Platform Installation
Put the platform back in the printer and plug the heatbed cable in. Both big and small connectors need to be plugged in.
