Printed extruder cover is placed over the extruder in order to give protection to the extruder cable and all the cables plugged into the extruder PCB. The cover secures the extruder PCB on the aluminum extruder cover as well as functions as a distance piece between these two components. Therefore, if you notice visible signs of wear and tear on the printed extruder cover (cracks or breaks), replace the cover to avoid any kinds of failures.
At first, print the cover and then replace it according to this manual. The model is available to download here.
M Series Printing Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Unloading the Material
Upper Printed Extruder Cover Removal
Detach the upper printed extruder cover from the extruder.
Material Guide Removal
Detach the material guide from the extruder cover.
Unplugging the Extruder Cable
Unplug the extruder cable.
Unplug all the cables from the extruder PCB: the fans cable, the heater & thermocouple cable and the extruder motor cable.
Unscrewing the Extruder PCB
Unscrew the two screws securing the extruder PCB using a 2mm Allen key. Remove the PCB from the extruder.
Lower Printed Extruder Cover Removal
Remove the lower printed extruder cover.
Lower Printed Extruder Cover Assembly
Attach the new lower printed extruder cover to the extruder.
Extruder PCB Assembly
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, e.g. by wrapping against each other.
Plugging the Extruder Cable
Plug the extruder cable in.
Material Guide Assembly
Attach the material guide to the extruder cover.
Upper Printed Extruder Cover Assembly
Attach the upper extruder cover to the lower cover.
