Platform maintenance is necessary to keep the platform in good condition and make the printing process easier. Also, platform maintenance is required while you encounter problems with platform calibration, especially the center point.
Once you carry out the maintenance work, your model will adhere to the platform properly and at the same time the print will be easily removeable. In addition, warpage becomes easier to avoid. Every platform maintenance should be followed by platform calibration. Follow the tips included in the maintenance guide as far as frequency of maintenance work is concerned.
Unplugging the Heatbed Cable
Unplug the big connector of the heatbed cable from the platform.
Platform Removal
Unplugging the Perforated Plate Cable
Unplug the two small connectors on both sides of the platform and remove the perforated plate cable.
Cleaning the Platform
Clean the platform from the material residues using a spatula.
While cleaning the platform with the spatula, be extremely careful not to damage the conductive path next to the perforated plate's small connector.
Unscrew the screws to separate the perforated plate from the heatbed.
Cleaning the Heatbed
Remove the material residues from the heatbed using a piece of cloth and, if it is necessary, use a spatula.
Cleaning the Perforated Plate with a Spatula
Turn the perforated plate over and clean it from the material remains using a spatula.
Cleaning the Perforated Plate with Sandpaper
Turn the plate over again. Use 320-400 grit sandpaper to smooth down the surface of the plate until its surface is matte.
Cleaning the Perforated Plate with Acetone
Wipe the perforated plate with a piece of cloth damped in acetone.
Securing the Perforated Plate
Secure the perforated plate to the heatbed with the screws. At the end loosen the two screws securing the platform in the centre position by 30-45 degrees.
Plugging the Perforated Plate Cable
Plug in the perforated plate cable on both sides of the platform.
Platform Installation
Put the platform back in the printer.
Plugging the the Heatbed Cable
Plug the big connector of the heatbed cable in.
Platform Calibration
Once the maintenance work is done, the platform needs calibration.
IF DURING THE M300 PLATFORM CALIBRATION THE RESULT ARE TOO HIGH (>0.4), YOU SHOULD TIGHTEN THE TWO PLATFORM SCREWS PLACED NEXT TO THE CENTER CALIBRATION SQUARE.
