Required Tools
Parts
If you encounter problems with extrusion during either the material loading or printing, the nozzle may require cleaning (see the manual – nozzle cleaning) or even replacement. Also, the nozzle needs replacing if you notice burn marks or material deficiency on the model. Follow these steps in case the cleaning does not help.
Unloading the Material
Nozzle Removal
Unscrew the nozzle clockwise. Use the nozzle key from the Starter Kit box. Removing the nozzle should take place while the extruder is still hot. When the nozzle is loose, take it out using pliers.
Turn off the printer and unplug the power cable. Wait about 15 minutes and let the machine cool down.
Nozzle Assembly
Install the new nozzle in the hotend and screw it counterclockwise using the nozzle key.
