In case of problems with extrusion (if loading the material is impossible) or the extruder motor (it makes a clicking sound), or if there is a material deficiency in your model, follow the steps from this manual. Cleaning the nozzle is a way to keep it in perfect condition and extend its lifespan.
Unloading the Material
Scrubbing the Nozzle
Take the spatula from the Starter Kit and gently scrub the material remains from the nozzle.
Nozzle Removal
Unscrew the nozzle clockwise. Use the nozzle key from the Starter Kit box. Removing the nozzle should take place while the extruder is still hot. When the nozzle is loose, take it out using pliers.
Turn off the printer and unplug the power cable. Wait about 15 minutes and let the machine cool down.
Cleaning the Nozzle
If you were printing with Z‑GLASS / Z‑PETG / Z‑PCABS, print a small-sized object using Z‑ABS. This will help to extrude Z‑GLASS / Z‑PETG / Z‑PCABS remains from the nozzle.
Using the pliers, place the nozzle in a container filled with acetone.
Make sure that the nozzle is cold before putting it into the container.
Removing the Nozzle from the Container
After 8-10 hours take the nozzle out of the container with pliers.
Nozzle Assembly
Install the nozzle in its place in the hotend and screw it counterclockwise using the nozzle key.
