In order to avoid damages during shipment, the M300 is packaged in foil, foams and other protective materials. Unpacking of the M300 needs to be dealt with carefully as the fragile elements of the printer may be damaged during the process. Once you receive the box with the printer, follow this manual to properly unpack your M300.
Opening the Box
Opening the Box
Open the box and remove the box with side covers. Next, remove the upper cushioning.
Taking the Printer out of the Box
Take the 3D printer out of the box. Bearing in mind the printer’s weight (30kg), M300 should be taken out of the box by two people.
When lifting or moving the printer, do not grab:
  • belts
  • shipping clips
  • extruder
Removing the Foil
Removing the Foil
Remove the foil.
Removing the Shipping Clips
Remove the shipping clips.
Removing the Foams with Accessories
Remove the foams with accessories.
In the Box
In the Box
The graphic shows the whole box content.
