The following table summarizes all technical specifications and operational characteristics of Zortrax M Series 3D printers.
Weight and Physical Dimensions
M200 M300
Without a Spool 345 x 360 x 430mm [13.6 x 14 x 17in] 490 x 490 x 590mm [19.3 x 19.3 x 23.2in]
With a Spool 345 x 430 x 430mm [13.6 x 17 x 17in] 490 x 560 x 590mm [19.3 x 22 x 23.2in]
Shipping Box 460 x 470 x 570mm [18 x 18.5 22.4in] 576 x 576 x 842mm [22.7 x 22.7 x 33.2in]
Shipping Weight 25kg [55lbs] 56kg [124lbs]
Net Weight 16kg [35lbs] 30kg [66lbs]
Printing
Printing Technology LPD – Layer Plastic Deposition
Layer Resolution 90 – 400 microns 140 – 300 microns
Wall Thickness Optimal: 800 microns
Positioning Precision X/Y 1.5 microns
Z Single Step 1.25 microns
Dimensional Accuracy +/- 0.2%*
Angle Accuracy +/- 0.2%**
3D Printer
Workspace 200 x 200 x 180mm [7.87 x 7.87 x 7.086in] 300 x 300 x 300mm [11.81 x 11.81 x 11.81in]
Material Container Spool
Material Diameter 1,75mm [0.069in]
Nozzle Diameter 0,4mm [0.015in]
Support Structures Removed mechanically – printed with the same material as the model
Extruder Single
Connectivity SD card [included]
Available Materials Full offer is available at: https://zortrax.com/materials/zortrax-m-series/
Additional Information Each delivered printer may have worked up to 50 hours during the quality control test prints Each delivered printer may have worked up to 90 hours during the quality control test prints
Temperature
Extruder Maximum Temperature 380˚C [716˚F]
Platform Heated
Platform Maximum Temperature 110˚C [230˚F]
Ambient Operating Temperature 20 – 35˚C [68 – 95°F]
Storage Temperature 0 – 35˚C [32 – 95°F]
Electrical
AC Input 110/240V ~ 2A 50/60Hz
Power Requirements 24V DC @ 11A
Power Consumption max 300W max 500W
Software
Software Package Z-SUITE®
Supported File Formats .stl, .obj, .dxf, .3mf
Supported Operating Systems Mac OS X / Windows 7 and newer versions
*It should be noted that the model’s dimensions strongly depend on the technical condition of the printer as well as the shape, form and size of a print, the material used and the printing process conditions. The accuracy in Z axis does not include a tolerance of +/- one layer. Bear in mind errors of measurement and measuring equipment.
**measurements were taken with an angle of 90˚
