In order to avoid damages during shipment, the Inventure is packaged in foil, foams and other protective materials. Use extra care while unpacking the Inventure as the fragile elements of the printer may be damaged during the process. Once you receive the box with the printer, carefully follow the steps provided in this manual to properly unpack your machine.
Opening the Box
Opening the Box
Open the box and remove the cushioning.
Removing the Boxes
Removing the Boxes
Remove the boxes with accessories.
Taking the Printer out of the Box
Use the handles to take the printer out of the box. The handles are on both sides of the housing.
Removing the Foil
Removing the Foil
Remove the security foil.
Removing the Foams
Removing the Foams
Open the top door and remove the plastic foams holding the extruder.
In the Box
In the Box
The graphic shows the whole box content.
