The following table summarizes all technical specifications and operational characteristics of Zortrax Inventure 3D printer.
Weight and Physical Dimensions
Overall Dimensions 350 x 350 x 400mm [13.7 x 13.7 x 15.7in]
Shipping Box 460 x 470 x 570 mm [18 x 18.5 22.4in]
Shipping Weight 25kg [55lbs]
Net Weight 22.5kg [49.6lbs]
Printing
Printing Technology LPD Plus – Layer Plastic Deposition Plus
Layer Resolution 90 – 200 microns
Wall Thickness Optimal: 800 microns
Positioning Precision X/Y 1.5 microns
Z Single Step 1.25 microns
3D Printer
Workspace 135 x 135 x 130mm [5.3 x 5.3 x 5.1in]
Material Container Cartridge
Material Diameter 1,75mm [0.069in]
Nozzle Diameter 0,4mm [0.015in]
Support Structures Dissolvable – printed with a different material than the model
Extruder Single; printing with the model and the support material
Filter HEPA
Chip transferring material information (type, color, consumption) Yes
Connectivity SD card [included]
Available Materials Full offer is available: here.
Temperature
Extruder Maximum Temperature 380˚C [716˚F]
Chamber Heated
Platform Maximum Temperature 90˚C [194˚F]
Ambient Operating Temperature 15 – 35˚C [60 – 95°F]
Storage Temperature 0 – 35˚C [32 – 95°F]
Electrical
AC Input 110/240V ~ 2A 50/60Hz
Power Requirements 24V DC @ 7A
Power Consumption 160 W
Software
Software Package Z-SUITE®
Supported File Formats .stl, .obj, .dxf, .3mf
Supported Operating Systems Mac OS X / Windows 7 and newer versions
