Extruder PCB is the part to which all extruder components are connected. Therefore, if any of these components malfunctions or does not work at all, at first check a given component for proper functioning. If everything seems to be working properly but you notice hanging strands on your model and the printer overheats, consider replacing the extruder cable. If these solutions do not help, you can be sure that the PCB is damaged and needs to be replaced.
NOTE: If the material is loaded into the extruder, unload the material using the “Material” -> “Unload material” option in the printer menu.
M Series Printers Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Unplugging the Extruder Cable
Unplug the extruder cable.
THE MANUAL SHOWS THE EXTRUDER WITH THE TOP COVER V1. WE RECOMMEND REPLACING THE COVER V1 WITH THE COVER V2 FOR EXTRUDER CABLE PROTECTION REASONS. See the manual.
Upper Printed Extruder Cover Removal
Detach the upper printed extruder cover from the extruder.
Unplug all the cables from the extruder PCB: the cooler cable, the thermocoupler & heater cable and the extruder motor cable.
Unscrewing the Extruder PCB
Unscrew the two screws securing the extruder PCB board using a 2mm Allen key. Remove the PCB from the extruder.
Extruder PCB Assembly
Place the new extruder PCB in its place and secure it with the two screws.
Plugging all the Cables into the Extruder PCB
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, eg. by wrapping against each other.
Upper Printed Extruder Cover Assembly
Attach the upper extruder cover.
Plugging the Extruder Cable
Plug the extruder cable in.
