Extruder motor is responsible for loading the material into the hotend. Therefore, if you can hear a clicking sound coming from the extruder motor during the material loading or printing, or if the material gets blocked in the extruder, the extruder motor needs replacement. This manual shows how to replace the extruder motor.
M Series Printers Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Unloading the Material
Unplugging the Extruder Cable
Unplug the extruder cable.
THE MANUAL SHOWS THE EXTRUDER WITH THE TOP COVER V1. WE RECOMMEND REPLACING THE COVER V1 WITH THE COVER V2 FOR EXTRUDER CABLE PROTECTION REASONS. See the manual.
Upper Printed Extruder Cover Removal
Detach the upper printed extruder cover from the extruder.
Unplug all the cables from the extruder PCB: the cooler cable, the heater and thermocoupler cable and the extruder motor cable.
Unscrewing the Extruder PCB
Unscrew the two screws securing the extruder PCB board using a 2mm Allen key. Remove the PCB from the extruder.
Front Printed Extruder Cover Removal
Remove the front printed extruder cover.
Unscrewing the Aluminium Extruder Cover
Unscrew the screws securing the aluminum extruder cover on both sides of the extruder. Separate the cover from the extruder motor.
Unscrewing the Extruder Motor
Unscrew the four screws securing the extruder motor.
Extruder Motor Removal
Separate the extruder motor from the extruder block.
Extruder Motor Assembly part 1
Reattach the extruder motor to the extruder block.
Extruder Motor Assembly part 2
Secure the motor with the screws. Press the motor to the right side so that the bearing rack is as close as possible to the bearing. Tighten the screws crosswise in the following order: 1-4, 2-3.
Aluminium Extruder Cover Assembly
Reattach the aluminum extruder cover to the extruder and secure it with the screws.
Front Printed Extruder Cover Assembly
Attach the front printed extruder cover to the extruder.
Extruder PCB Assembly
Plugging all the Cables to the Extruder PCB
Plug all the cables in. Remember to arrange the cables so that they don’t get damaged, eg. by wrapping against each other.
Upper Printed Extruder Cover Assembly
Attach the upper extruder cover.
Plugging the Extruder Cable
Plug the extruder cable in.
