Extruder cable replacement should take place if you encounter problems connected with the extruder. Therefore, if the extruder heating is insufficient (it heats up only to 50%) or you can hear a clicking sound coming from the extruder motor and the pulley moves back and forth, or your model is incomplete (it has irregular layers/walls and there is a lack of material on the top and bottom part of the print), the extruder cable may be broken.
M Series Printers Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Unplugging the Extruder Cable
Unplug the extruder cable.
THE MANUAL SHOWS THE EXTRUDER WITH THE TOP COVER V1. WE RECOMMEND REPLACING THE COVER V1 WITH THE COVER V2 FOR EXTRUDER CABLE PROTECTION REASONS. See the manual.
Grab the printer’s housing and change the printer’s position so that you get an easy access to the bottom plate.
Unscrewing the Bottom Plate part 1
Unscrew the screws securing the bottom plate on one side of the housing. Use a 2,5mm Allen key.
Turning the Printer
Turn the printer over.
Unscrewing the Bottom Plate part 2
Unscrew the screws securing the bottom plate on the other side of the housing. Use the same key.
Separating the Bottom Plate
New Version of the Motherboard
The photos show the new version of the motherboard in M200. The extruder cable connection is placed underneath the motherboard so you can use the extruder cable without an adapter.
Extruder Cable Removal
Unfasten the two extruder cable straps and unplug the cable from the motherboard. Next, unfasten the third strap and remove the cable through the hole. Finally, open the three cable clamps and remove the extruder cable.
Extruder Cable Assembly
Place the cable in the cable clamps and secure it by closing the clamps. Next, put the cable through the hole and secure it with the first strap. Plug the extruder cable into the motherboard and fasten the two remaining straps.
Old Version of the Motherboard
The photos show the old version of the motherboard. The extruder cable connection is placed on top of the motherboard. That is why, you have to use the extruder cable with an adapter.
Unfasten the two extruder cable straps and unplug the cable from the motherboard. Next, unfasten the third strap. Open the three cable clamps and remove the extruder cable from the clamps and finally remove it through the hole.
Put the extruder cable through the hole and place in the clamps. Close the clamps. Fasten the first stap and plug the extruder cable into the motherboard. Fasten the two remaining straps.
Bottom Plate Installation
Screwing the Bottom Plate part 1
Screw the bottom plate on one side of the housing. Use a 2,5mm Allen key.
Turning the Printer Over
Screwing the Bottom Plate part 2
Screw the screws securing the bottom plate on the other side of the housing. Use the same key.
Grab the printer’s housing and place the printer vertically.
Plugging the Extruder Cable
Plug the extruder cable in.
