In order to avoid damages during shipment, the Zortrax DSS station is packaged in foil and other protective materials. Use extra care while unpacking the Inventure as the fragile elements of the device may be damaged during the process. Once you receive the box, carefully follow the steps provided in this manual to properly unpack the station.
Opening the Box
Opening the Box
Open the box and remove the cushioning.
Taking the Zortrax DSS out of the Box
Use the handles to take the Zortrax DSS out of the box. The handles are on both sides of the housing.
Removing the Foil
Removing the Foil
Remove the security foil.
In the Box
In the Box
The box also contains: rubber gloves, brush, drain pipe, quick start guide, rinsing basket.
