The bottom fan ensures keeping the proper temperature around the motherboard, and thus protects it from overheating. Therefore, if the bottom fan does not work (does not rotate properly) or you can hear a strange sound coming from the bottom of the machine, it is probably broken. Follow the instructions provided in this manual to see how to replace the bottom fan and avoid the motherboard failure.
M Series Printers Servicing
Therefore, maintenance and repair work can be carried out in the same manner with both models. The following manual shows M200 repair work. In the case of M300, these procedures look the same.
Turn off the machine and unplug the power cable. Wait a few minutes for all the capacitors to discharge.
Reposition the printer to access the bottom plate.
Unscrewing the Bottom Plate part 1
Unscrew the screws securing the bottom plate on one side of the housing. Use a 2,5mm Allen key.
Turning the Printer
Turn the printer over.
Unscrewing the Bottom Plate part 2
Unscrew the screws securing the bottom plate on the other side of the housing. Use the same key.
Separating the Bottom Plate
Unscrewing the Bottom Fan
Unscrew the bottom fan from the plate using a 2,5 mm Allen key. Remove the bottom fan cable from the clamp and separate the fan from the bottom plate.
Bottom Fan Installation
Bend the bottom fan cable and place it in the clamp. Install the bottom fan in its place and secure it with the screws.
Bottom Plate Installation
Securing the Bottom Plate part 1
Screw the bottom plate on one side of the housing. Use a 2,5mm Allen key.
Turning the Printer
Securing the Bottom Plate part 2
Screw the screws securing the bottom plate on the other side of the housing. Use the same key.
Place the printer in its initial position.
