Method with jigs is basic maintenance work to be carried out while dealing with the problems of: shifted layers or deformation of your model, measurement differences between the designed model and the final print, or if the extruder doesn’t move freely (it makes unusual sounds while moving on the guide rails). The following method will significantly help you eliminate these problems and achieve the expected quality and measurements of the model.
Unplugging the Extruder Cable
Unplug the extruder cable.
JIGS Assembly
JIGS Assembly
Put the jigs on the extruder guide rails and move the extruder manually so that the jigs are touching the X axis. This way, you will check if the extruder guide rails are parallel to the X axis. If not, follow the steps in this manual.
Locking the Block
Put the shipping clips on the Y axis next to the axis block so that it won’t move.
Pushing the Block
Pushing the Block
Push the opposite block forward until it clicks (the belt will move by one tooth on the rack).
Do not use too much force or the belt will skip too far.
Tensioning the Belts
Check the belts for proper tension.
a) Check both the upper and lower belt. If the belts are properly tense, you can finish the maintenance work.
b) If not, take a piece of tape and put it on the belt.
Then move the extruder manually back and forth so that the tape gets on the rack. Remove the tape.
Finishing Axes Maintenance
Again use the jigs to check if the extruder guide rails are parallel to the axis. If not, start again from the step no. 4.
